Serpantine belt?
Old 04-02-2008, 02:07 PM
SSjunkie912's Avatar
Default Serpantine belt?
Any clue how to get it back on after installing an alternator? the tensenior is as loose as can be and i wiggled the alternator a million different ways...
Old 04-02-2008, 02:13 PM
my bandit's Avatar
is the belt going the way it should be
Old 04-02-2008, 02:17 PM
yep the belt is going exactly as it should....im only like a half an inch of belt short of fitting perfectly....
Old 04-02-2008, 02:47 PM
i should add thats its too tight, not too loose!
Old 04-02-2008, 11:25 PM
ghardester's Avatar
You route it over all the pulleys they way it should be, be sure the belt fits in the pulley grooves. Put a socket wrench on the end of the tensioner. When you pull on the wrench the tensioner moves. Slip the belt over the tensioner. It can be tight!
