Stereo & Electronics - Has anyone ever used this sub box before?
Brian2006
04-02-2008, 11:40 PM
http://www.hifisoundconnection.com/Shop/Control/fp/sret/14192101921821716225282211218219284231226287222235 29022122822529622522822923824524624324024724624325 0/vpid/2395090/vpcsid/0/SFV/30046/sret/14192101921821716225282211218219284231226287222235 29022122822529622522822923824524624324024724624724 0
http://a763.g.akamai.net/7/763/1644/11/app.infopia.com/img/image/fp/VPID/2395090
http://a763.g.akamai.net/7/763/1644/9/app.infopia.com/img/image/fp/extra/2/VPID/2395090
It's about $25 cheaper after shipping costs and the quality appears to be pretty good. Unfortunately, it doesn't say the airspace but it appears to be pretty high quality.
Gordon0652
04-02-2008, 11:47 PM
Someone on here had that box and it stuck out and fitment sucked!
Try googling Subthump
They make an amazing box!
Brian2006
04-02-2008, 11:54 PM
Well that's good to know. I already have subthump's amp rack and my process of making a fiberglass box is going still cost me about $150 with a lot of labor. Is it really worth it???
Gordon0652
04-02-2008, 11:58 PM
I rather just buy the box because you dont have to mess around with the fitting, and also they cut the hole to fit your speaker.
150$ to make one of these boxes?!?!? Are you making it out of gold? lol You can make one for lets say 50$.
SleeperZzZ28
04-03-2008, 12:19 AM
I have a subthump and it fits great and sounds good
Brian2006
04-03-2008, 12:27 AM
Each gallon of the resin is $31. I'm gonna need 3 gallons when it's all said and done... Then I gotta buy a couple packs of fiberglass sheets, the bondo milkshake, already bought the MDF and cut out the hole, and then I gotta buy the carpet. However, there's no possible way to get a larger airspace out of it...
I have a 10" Type S sub. Is it worth it?
DarkJuggalo
04-03-2008, 06:19 AM
that box is disgusting , my buddy has one just like it. might be that one looks just like it, its awful. fitment was very very poor. i bought a ported single 12" box that fits in the ttop holder just right. take up the whole space so theres no gap. its not loud enough though, so i just bought a dual 12" subthump off classifieds here :D
No Juice
04-03-2008, 07:14 AM
I believe the one posted above has about 0.5cuft of air space. It looks the same design someone was selling on here a few weeks ago. He was making them out of his house and that was the air space he calculated. The subthump one has about 0.6 and the KeeAudio one has about 0.7. I was planning on making my own out of fiberglass as well but now that you said what the costs are, I may have to rethink that.
Gordon0652
04-03-2008, 07:23 AM
I would get something a bit more powerful that the S-type IMO, maybe like the R-type.
S-type would work but the R-type might proform better because of the wattage that it can handle.
I have heard a few stealth boxes and some of them had low power 10" subs and i though stock sounded just as good! Never heard the type-R but i bet thats a beast with 500 watts RMS hooked up to it!
Also KEEAUDIO sells stealth boxes.
KEE AUDIO
04-03-2008, 09:31 AM
3 gallons of resin is way too much.
I use 1 layer of fiberglass cloth to make the area smooth and then use 3 layers of fiberglass chopped mat and use about right at or a little over a quart of resin. I roll it on with a small paint roller to keep as many airpockets out of it as I can. This also helps to distribute the resin evenly. I then coat the inside with truckbed coating which helps with the sound deadening and sealing.
bmnicolosi
04-03-2008, 09:04 PM
beat me to saying that one. There is no way you should even use a gallon, much less 3 of resin. i would say you should be able to get it done with a half gallon---thats taking account for you not being perfect with using it and having some wasted resin.
thecobrahunter
04-03-2008, 11:00 PM
I like by subthump pair. Plus the sound is killer!
http://memimage.cardomain.net/member_images/8/web/392000-392999/392726_165_full.jpg
http://memimage.cardomain.net/member_images/8/web/392000-392999/392726_107_full.jpg
http://memimage.cardomain.net/member_images/8/web/392000-392999/392726_202_full.jpg
Plus, with the hatch cover on, it's like an enclosure.
