All bore 383?
Old 04-03-2008, 06:09 AM
antivtec69's Avatar
Default All bore 383?
Ive heard these are crazy torquey. How much would it be to build the bottom end? I know it has to be bored far, but can you use the stock sleeves? You cna use the stock crank too right?
thanks
Old 04-03-2008, 06:17 AM
s346k's Avatar
all of the information you need is here
https://ls1tech.com/forums/dynamometer-results-comparisons/836325-all-bore-383ci-vic-jr-numbers.html
search?
Old 04-03-2008, 07:36 AM
antivtec69's Avatar
yeah that was on a 6.0 block though...I was just wondering how far you could go no a stock LS1 block w/ stock sleeves
Old 04-03-2008, 08:25 AM
s346k's Avatar
you won't get 383 cubes out of a stock crank and block ls1.
Old 04-03-2008, 09:50 AM
1CAMWNDR's Avatar
The stock sleeves can only be overbored .010" I think. Very far from a 383. You'd be better starting with an LS3 or L92 block. But even then I don't think you will get to overbore it to 383".
Old 04-03-2008, 10:33 AM
teke184's Avatar
exactly...the stock sleeves are too thin to bore out that much.
resleeve or use a different block
Old 04-03-2008, 11:02 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Agreed
Old 04-03-2008, 11:11 AM
david vericker's Avatar
The 3.905 cylinders (honed) on a 383 LS1/LS6 is only worth one cubic inch. The 4.00 stroke makes up the additional 36 cubic inches. The only way to increase the bore size on the LS1/LS6 is to re-sleeve the cylinders...and that is very expensive and not worth the cost.
Old 04-03-2008, 11:56 AM
BlackNiteWS6's Avatar
Gotta love big bore...GM gave us enough stroke. If i did a stroke motor i would go the LSX or LS7 route with a 4.125" bore. That's a 387cid, but close enough.
