NGK TR55 is the 55 the gap?
I keep getting radom misfire code p0300 I have the AC delco iridium spark plugs & expensive taylor wires been in for only 25K miles.
the code appears (chech engine lite) then go'es away. zero preformance loss.
anyway I'm planning a spark plug swap w/ the NGK TR55 is the 55 the gap?
55thousands?
Thanks
55thousands?
Thanks
Exactly! Mine were right on. Just be carefull checking them. I eased the gap checker on and it still managed to hang and get stuck between electrobes . No stratches or damage thakfully.
checking wires
I changed the plugs and am still getting the check engine light.
first day no light thought I fixed it second day dam check engine light comes back then goe's goe's off for a few days.
when I install spark plug wires I make sure they click once one the plug and twice on the coil.
are you suggesting to check the wires with a multimeter?
these are preuiem taylor wires.
Thanks
Thanks
