Where the hell can i rent or buy a Rear main seal installer tool????
Old 04-03-2008, 03:29 PM
CamaroRacing12's Avatar
Default Where the hell can i rent or buy a Rear main seal installer tool????
i've called 4 auto parts stores and have had 0 luck... anyone help me out?
Old 04-03-2008, 11:35 PM
anybody!?
Old 04-04-2008, 12:07 AM
ttop1986's Avatar
http://lt1tech.com/cgi-bin/ultimateb...c;f=9;t=003478
check out that thread
Old 04-04-2008, 12:16 AM
cgroh89's Avatar
When are you doing yours ? I am replacing mine on Monday Ill let ya know how it goes
Old 04-04-2008, 09:52 AM
Koll's Avatar
I think when I did the RMS on my 350 TPI (which is 1 piece) I just tapped it in evenly with a block of wood or some crap.
Old 04-04-2008, 10:23 AM
DopdBrd's Avatar
Yeah, you don't need a special tool. I just used a rubber mallet to do mine. Even if you are popping it out, just use a screwdriver.
Old 04-04-2008, 10:56 AM
ulakovic22's Avatar
Go to Home Depot and get a 1x6, lay it across and beat the **** out of it. You can use this tool on your front timing cover too when installing cranks and opti seals
Old 04-04-2008, 01:32 PM
i dn us ure not using the correct tool what make it go in unevenly caushing major oil leaks.... and then have to drop the tranny again?
Old 04-04-2008, 01:44 PM
97LT1's Avatar
I replaced mine when I did a clutch change for good maintenance. I just tapped it in in circular motion with a small hammer. I think you just want to focus on being even when driving it in.
Old 04-04-2008, 01:46 PM
the_merv's Avatar
Pop it out with a Hammer and a Screw Driver..
I put it in using a Hammer tapping it around evenly like mentioned above, after it goes all the way in tap all around it to make sure it's completely flush in the Seal Housing.
Old 04-04-2008, 05:31 PM
sounds simple enough
Quick Reply: Where the hell can i rent or buy a Rear main seal installer tool????
