o2 extension's, home made
Shirley Temple Drinker
Alright when I did my motor swap I added lt's, so instead of buying extensions I extended the harness on the passenger side, and have no problems with it. but on the driverside I extended the harness right on the 02, instead of the harness, and that o2 is reading wack, but it is a bosch so I think its just bad. whose extended harnesses and had it work perfectly, and how did you do it, on the 02 or on the engine harness?
