96 misfire partially fixed...not all the way tho...depressing....
Old 04-03-2008, 09:24 PM
simster571's Avatar
Default 96 misfire partially fixed...not all the way tho...depressing....
well after installing my headers, I got a misfire. Found out the front o2 sensors were disconnected, replaced them tonight and the problem is fixed for the most part...but im still getting a slight misfire, enough to throw a p0300 code and be a noticeable loss in power. what could i have unhooked, disconnected, screwed up to cause this??? im really starting to regret this whole headers idea....
Old 04-03-2008, 09:26 PM
nomoneyz's Avatar
Double and triple check your plug wires. I don't know what else. Did you extend the O2's yourself or buy extensions?
Old 04-03-2008, 09:33 PM
simster571's Avatar
bought extensions.....the problem was way worse before when i extended it myself. Put on extensions and new o2 sensors. I have all new wires and heat boots on them. Neither the o2's nor the wires should be the problem.
Old 04-04-2008, 09:24 PM
alaureano's Avatar
Did You Check Actual Vaules With The Scaner ? Do You Notice Anything Out Of
Spec Like O2 Sensors Staying At A Certain Reading? DOES YOUR HEADERS HAVE EGR AND AIR FITTINGS?
Old 04-04-2008, 10:07 PM
simster571's Avatar
yes the headers were the emissions style headers with the EGR and the AIR fittings.
I did not check actual values, I dont have access to a scanner so I just take the car the autozone and have them tell me the codes. Im sure the o2's are fine, they are brand new.
I have a pcmforless tune on the way, im hoping that the tune might fix the problem. If not, i guess ill see about the opti..
Old 04-05-2008, 01:02 PM
doug1105's Avatar
IMHO, I wouldn't dig into the opti unless you get an opti code.
Check the plug wires again and get a buddy to look with you.
Check all of your connections, even the brand new stuff.
Sometimes an new set of eyes sees something you missed.
Old 04-05-2008, 04:25 PM
simster571's Avatar
i scanned today and got a new code - p0441 -Evaporative emission control system incorrect purge flow
im gonna do some research on it, hopefully this may be it.
Old 04-05-2008, 09:52 PM
alaureano's Avatar
So You Have Code That Could Mean You Have A Faulty Purge Vale. That May Cause A Misfire Becuase The Purge Valve Alows Fuel Vapor Stored In The Evap
Canister To Enter The Intake Before The Maf Sensor Making The Mixture Richer Then It Has To Be. If It Is Stuck Open Then Will Aways Allow Fuel Vapor To Enter The Intake No Matter What The Pcm Wants To Do. Take It Off And See If Its Stuck Open. It Should Always Be Closed. Or It Can Stick When It Gets Activated.
Old 04-05-2008, 10:06 PM
simster571's Avatar
what is the purge valve? where is it located? how do i take it off?
thanks
Old 04-05-2008, 10:37 PM
alaureano's Avatar
It Allows Fuel Vapor Stored In The Evap Canister To Enter The Engine After The Air Flow Meter. The Pcm Decides When Its The Best Time Open It And It Normaly Operates In Crusing Conditions. You Should Be Able To Find The Location On The Emissions Sticker In The Engine Compartment. If You Dont Have This Sticker Anymore The Follow The Vacume Lines From The Throtle Body And See If You Find A Line Thats Conected To Solinoid. I Would Go Outside To My Car To Give A Better Idea But 11:30 Pm And I Dont Have Flash Light.
Old 04-05-2008, 10:42 PM
alaureano's Avatar
On My 1994 Z28 Its Located On The Pass Of The Intake Manifold. You Shold Have 1 Line Coming From The Fuel Tank And Another Going To The T-body.
Old 04-05-2008, 10:49 PM
alaureano's Avatar
I Also Made A Mistake In The First Line Saying That The Valve Allows Fuel Vapor To Enter The Intake Before The Maf. It Enters It After The Maf Sensor. Thats Why If Its Stuck Open It Can Run Rich. The Maf Does Not Have Any Way To Correctly Measure Fuel Vapor.
Old 04-05-2008, 10:55 PM
alaureano's Avatar
If Its In The Same Location I As My 1994 Z28,i Would Plug The Hole On The T-body And Pluge The Hole On The Valve So You Take It Of The System Without
Setting Any Code That Relate To Electonic Failures As Dtc P0443
Old 04-05-2008, 11:19 PM
simster571's Avatar
the hose is compleatly off and cracked and screwed, so that is definatly the problem. Ill get a new hose tommarrow. thanks for the help.
I replaced the coil wire and it made a huge diffrence on the misfiring. Im starting to feel alot better about it. Exhaust makes wierd noises, but there is a leak at the collector so im not to worried about it right now, ill get it welded up monday
It still shakes at low RPM under 1/2 throttle or more, but im thinking it just because of that vacuum leak from that hose. Im going to autozone tommarrow to get that fixed, dealer on monday to get a new coolant temp gauge wire, and my pcmforless tune should be in by tuesday or wednesday.
life is getting better. lol
Old 04-05-2008, 11:24 PM
alaureano's Avatar
Yes!!!! I Finally Hit 1 On The Nail With The Diagnosis!!!!! I Am Glad That You Found The Problem!!!! Keep In Touch!!!
Old 04-05-2008, 11:29 PM
simster571's Avatar
well ill know for sure tommarrow on my adventures with it, the 15 minute test drive tonight was a success in my book tho, even scratched when i shifted into 2nd and 3rd, something that hasnt happened in a good while! thanks for the help!
Old 04-05-2008, 11:46 PM
alaureano's Avatar
Please Let Me Know What Happens After You Fix It!!!! I Hope The Worse Of It Is Finaly Over!! If You Need Any More Help Just Letme Know.
