white smoke after cam swap
Old 04-04-2008, 01:52 AM
kratos2250's Avatar
Default white smoke after cam swap
Just did a cam swap and I know I gotta get a tune but is it normal to have a little white smoke? it's comming from my tailpipe and it's just a littlt bit. When it warms up it goes away. could this be from the misfires. I filled my radiator up with green coolant before I knew You should put the dexicool in. so I switched it out today. Didn't know if that had anything to do with it.
Old 04-04-2008, 07:53 AM
kratos2250's Avatar
And it olny happens during idle.
Old 04-04-2008, 08:32 AM
black01_WS6's Avatar
what valve springs did you go with? did you replace the valve seals.
Old 04-04-2008, 08:41 AM
minytrker's Avatar
sounds like valve seals to me
Old 04-04-2008, 10:17 AM
road agent's Avatar
White smoke usually indicates coolant is being burned. Blue smoke is typical for oil burning.
Old 04-04-2008, 10:22 AM
newtoLS1s's Avatar
does it smell sweet? or smokey?
Old 04-04-2008, 12:12 PM
68birdls1's Avatar
Old 04-04-2008, 12:37 PM
kratos2250's Avatar
Can't believe it. I took off the valve cover on one side and 6 of the 8 valve stem seals were not even seated. Guess I didn't put them on properly, so I reseated them and tapped them down on there now theres not much smoke at all, so I'll get to the other side tommorow. Thanks guys.
Old 04-04-2008, 12:57 PM
LS1nut377's Avatar
good luck
Old 04-06-2008, 12:13 AM
408z28's Avatar
+1
Your loose valve stem seals wouldn't cause a "WHITE" smoke issue. White smoke is coolant...not oil burning. Do a pressure test on your cooling system to see if you have a head gasket sealing issue.
Old 04-06-2008, 11:08 AM
kratos2250's Avatar
well that didn't get rid of it the smoke is light blue.
Old 04-06-2008, 11:12 AM
Restricted User
socmguy's Avatar
you did the other side's valve seals too?
Old 04-06-2008, 12:09 PM
kratos2250's Avatar
yep done both sides.
Old 04-06-2008, 12:19 PM
DaddySS's Avatar
Did you damage the seals? Are you certain you got them reseated and they are in good shape?
Old 04-06-2008, 12:41 PM
tacklebox's Avatar
Hmm i've had a little white smoke on startup ever since the h/c swap. Never thought anything of it.
Old 04-06-2008, 01:29 PM
kratos2250's Avatar
The seals were fine just, like new when I reseated them. Maybe it's just they are cheap? I got them in a cam package from TSP there the blue and grey ones. I crunk it up today and it looked alot better just a tad bit of smoke maybe they'll seat there self over time. Just in case it is the seals where can I buy a really good set, because taking those springs off is a pain in the ***.
Quick Reply: white smoke after cam swap
