Rear swaybar upside down!!! Endlinks?
Please excuse the length, but I need help ASAP so I don't ruin my Konis. So when my Moser 12 bolt was installed, the rear swaybar was installed upside down. Now that I changed my shocks (Koni) and springs (Strano) I noticed this. So currently the bushings that go around the axle fit fine. I think the shop used u bolts for a 9" rear because it also has an axle that is 3" in diameter. Herein lies the problem:
The endlinks are bent and and are rubbing on my shocks. I need to know what endlinks will work. I plan on installing the stock rear swaybar CORRECTLY today, but I need to find new endlinks. I know there are aftermarket kits that allow you to install rear swaybars on aftermarket rear ends. But I don't need a whole kit, just the endlinks. Will stock endlinks work? Plus, I plan on upgrading to Strano swaybars eventually, so I don't want to buy poly endlinks yet because I will get new endlinks when I purchase those. Thanks guys, any input would be appreciated.
Just go over to you local parts store and tell them your make and model and they should have endlinks. I broke one of mine last week trying to release the sway bar so I could install my Koni's and strano's. I just went over to Advance Auto Parts and they had them for around $5 a piece. They will work fine until you get Sams sway bars as I plan to do.
The stock endlinks will work even though I have a Moser 12 bolt. I know the endlinks don't connect to it, but I don't want the rearend to get in the way. Also do all the bushings and nuts come with new endlinks?
