What to use to clean carbon off pistons??
Old 04-04-2008, 08:43 AM
Bill Bowling's Avatar
Default What to use to clean carbon off pistons??
Should I just scrap the carbon off or use some type of cleaner?
I was thinking of scraping the heavy carbon off and cleaning the rest with a cleaner. What about brake cleaner?
Bill
Old 04-04-2008, 08:52 AM
2002ws-6's Avatar
I used a 3m plastic abrasive wheel from the boby work section of AutoZone. It was the brown colored one, I made sure it wouldn't cut into the pistons first. I would recomend masking off all the coolant pasages and lifter tray areas first.
Old 04-04-2008, 08:54 AM
Formula96's Avatar
brake cleaner and a little elbow grease...
Old 04-04-2008, 09:12 AM
Randy WS6's Avatar
lacquer thinner,let them soak for a while and it will wipe right off.
Old 04-04-2008, 09:37 AM
Sigforty's Avatar
Sea foam on a rag works really well. Not only can you run it through the engine, but you can also clean with it.
Old 04-04-2008, 09:56 AM
bsf
bsf's Avatar
Permatex gasket remover works awesome on the carbon build up.
Old 04-04-2008, 10:10 AM
prochargedchevyi's Avatar
+1
Gasket Remover plus a scotch brite pad. Then hit it again with some brake cleaner and wipe with a clean paper towel.
They should look pretty good after that.
Old 04-06-2008, 09:20 PM
BAD2000TA's Avatar
I just did this about a month ago. Good carb cleaner and a brass brush and they clean up like new.
Old 04-06-2008, 10:44 PM
Jasonscott's Avatar
second this. just got done doing mine. Used brake clean and a brass brush. cleaned up real easy and the brass wont scratch the pistons.
Old 04-06-2008, 10:46 PM
Jordan S.'s Avatar
x2. Lacquer thinner is great, it doesn't leave any kind of residue either.
Old 04-06-2008, 10:47 PM
Jordan S.'s Avatar
Use lacquer thinner and a shop towel, shop towels don't scratch them either.
Old 04-07-2008, 12:26 AM
Boosted 99 TA's Avatar
never tried lacquer thinner but gasket remover worked very well for me
Old 04-07-2008, 01:09 AM
redrider4's Avatar
dishwasher.
Old 04-07-2008, 02:32 AM
Jantzer98SS's Avatar
Sand blaster.
Old 04-07-2008, 04:46 AM
LS1C5Vette's Avatar
Wire brush on a drill
Old 04-07-2008, 06:30 AM
SS101's Avatar
so pretty much anything but steel wool lol
Old 04-07-2008, 07:02 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Wd-40 and a red scotch brite pad.
The some brake clean and a rag should finish her good.
I do not like anything stringent like brake clean or laquer thinner to take off build up with an abrasive pad becuase it could scratch. I worry about this more with cyl heads but I like to make sure its the same that when I left it.
Old 04-07-2008, 07:04 AM
brad8266's Avatar
oven cleaner works ok too.
Old 04-07-2008, 07:31 AM
xBROKEx's Avatar
+1 for seafoam
Old 04-07-2008, 10:30 AM
vettenuts's Avatar
Shouldn't be used on aluminum.
Quick Reply: What to use to clean carbon off pistons??
