lost 3rd and 4th gear any ideas?
Old 04-05-2008, 08:17 AM
QuickSilver's Avatar
Default lost 3rd and 4th gear any ideas?
got the car out of storage last Saturday and lost 3 and 4 on the way home.
Ran great all last season, it was rebuilt last spring.
Dont think its dirt in a valve because it went into 3 and 4 earlier on the drive home.
Any ideas guys?
Thanks
Josh
Old 04-05-2008, 09:18 AM
SoundsZ28's Avatar
i have the same problem with mine right now, i thought it was the trans, and i very well may be that, but i changed my fluid and filter and put the lucas oil in there and it shifts alot better now, but still slips sometimes going into 4th
Old 04-05-2008, 10:13 AM
hell i wish thats all i had when mine shifts to 3 or 4 there is absolutly nothing.
Old 04-05-2008, 11:25 AM
LS1Tech Sponsor
performabuilt's Avatar
Any ideas guys?
Thanks
Josh
When you say you lost 3rd and 4th Do you mean it goes to neutral when its supposed to make the shift or does it just hang in second?
Lucas can swell seals and temporarily improve function. Same question as before did it just simply not make the shift or did it nuetral where the 2-3 shift shouldhave been?
If you go to nothing "neutral feel" You have lost the 3-4 clutch set.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-05-2008, 11:52 AM
super_fro_daddy's Avatar
Thats what mine did. It happened 300 miles from but luckily it was all 2 lane roads but still driving in mostly 3rd w/3.73s was a bit annoying. When I pulled the pan out of curiosity - I was pretty sure it was done - the fluid looked like a friggin sparkle show!!
I now have a Level 2 w/PT4000 and no complaints here.
Old 04-05-2008, 01:25 PM
when the trans shifts to 3 or 4 just feels like its in neutral. if i get on the throttle pretty hard it kida wants to "surge" but doesnt pull.
Old 04-05-2008, 01:32 PM
Gilbert@Ace Racing's Avatar
Then the unfortunate reality is that the 3/4 clutches have failed or there is a significant hydraulic leak due to it sitting up. I doubt the hydraulic issue though.
Either way it is internal and needs to be removed and disassembled for inspection, rebuilt or replaced.
Good luck with the repairs... holler at me if you would like to explore some options.
g
Old 04-05-2008, 06:21 PM
GTO1_OHIO's Avatar
Sounds like the clutch pack is burnt. Did you just have it rebuilt OEM or did you buy a street/strip upgrade?
...and where in Ohio are you? This sounds exactly like what happened to my tranny last year...luckily I'm close enough to Rossler to have been able to drive it over for an upgrade so that I didn't have to screw with shipping it.
Old 04-06-2008, 06:58 AM
When it was rebuilt i just got a TCI kit and had a tranny guy install it.
I was only expecting to limp it along for a while.
Im not suprised just suckes it happened the first day the car came out.
Josh
Im in the Akron area
Old 04-06-2008, 07:34 PM
GTO1_OHIO's Avatar
The performance shop that tunes/installs my car is in Medina. They have a transmission shop they work with that could look at it. ...actually they are installing my 3.73 gears this week.
Old 04-06-2008, 07:49 PM
Backstreet?? My car was tuned on that dyno but not by them.
I have a trans lines up. Thanks tho
Josh
