Generation IV External Engine - Forged LS3 already built with L92 Heads. What heads/intake can I change to?
ForceFedC5
04-05-2008, 10:15 AM
Hello,
I have a forged LS3 with L92 heads/L76 Intake.
I'd like to make power to 7k and maybe even lower the compression about .5 to 1.
What head/intake options do I have?
I've been waiting a year for the aftermarkts L76 intakes and I've about lost my patience, especially since the aftermarket may not even be that much better.
Any advice would be greatly appreciated! :chug:
N4cer
04-07-2008, 11:46 AM
To keep it affordable, you would go with the L76 carb-style intake (single plane), and have a machine shop open up your combustion chambers. That's about all you can do.
camarols1
04-07-2008, 12:30 PM
+1
You can use intake #25534416 and an elbow to help high RPM breathing.
I think that it may not be worthwhile to tear apart an engine to make such a small change in compression.
Just my .02
Blindmelon
04-07-2008, 03:48 PM
The new Weiand intake comes out mid summer for L92 heads. Worth 30 hp & torque over the L76 intake. Here is video on it.
http://www.v8tvshow.com/forum/index.php?topic=143.msg437#msg437
WKMCD
04-07-2008, 04:27 PM
I'd like to see what the ET small bore LS7 heads would do with the right camming. The real benefit is you can run the LS7 intake which is a nice piece.
ForceFedC5
04-07-2008, 08:52 PM
He said the performance gain is up to 6200rpm :confused:
You'd think the aftermarket would go as high as a stock LS7 considering its going to go on mostly modded cars.
That kinda sux
ForceFedC5
04-07-2008, 08:54 PM
What cc's do the ET LS7 heads come in? I hear the valves are very heavy and may not be great for road racing?
Thanks!
