Possible to make over 550-600rwhp
With 383 stroker kit from texas-speed-
http://www.texas-speed.com/shop/item...d=884&catid=88
And MS4 and 2.5ported LS6 heads on an LS1-
http://www.texas-speed.com/shop/item...d=832&catid=47
I was thinking of this set-up But im still not sure just looking for some ideas and opinions on it.
And if anyone has this set-up and if they can give me any help and If i should bore out the stock block.
You should easily break 500 on a 408 unless you have a very high stall convertor and a TH400 trans. But for a 408, you will DEFINATELY need a bigger cam than a little MS4. Rough estimate, add 10 degrees duration to each lobe going from a 346 to a 408 for similar camshaft / cid ratio.
Lift will because the lobes will be bigger assuming you're just going with longer duration in the same lobe line (LSK, XFI, XE-R, XE for the common comp cams stick). Displacement absorbs overlap, so yes, the characteristics should be similar. You don't neccessarily need it ground on lobes with .700 lift or anything, you have to stay within your heads and valvetrain. If the heads back up or flow goes static at say, .650 then don't run a lift over .650 and make sure your springs can handle the lift. Don't be afraid of lift either though. 2 valve engines love more lift. I run .644 on my 228 intake lobe, nowadays these springs are made for it.
This set-up should be well over 550rwhp lets just hope it all goes as planned. Should have it finished after summer Right now T56 and the ls1 engine is out on a stand. I installed an 228/232 cam in it and after 6months of running good it just hit the *******. lifter grinded cam up.
