Brake Pad Help
Brake Pad Help
Hey guys, I've recently been having a squeaking noise coming from my passenger rear wheel area... I had my friend drive my car slowly down the street with me walking beside it so I could figure out where it was coming from and so far as i can tell it seems to be coming from the rear passnger wheel area...
my friend thinks i need to replace my pads. The previous owner of the car changed the rotors to slotted which is the reason my friend thinks i should change my pads to get rid of the noise.. but the previous owner never told me if he changed the calipers.. i took the wheel off today and on the rear passenger caliper it said PBR made in Australia..
I have 2 questions... first, is it possible that this noise is coming from the brakes. and second.. if i were to get new pads.. would I have to order some special ones or will any regular ones work??
Thanks guys.
Cheers.
EDIT: The squeaking noise is not the same type of noise heard from SQUEALING worn brakes... just wanted to clarify.
Thanks guys.
Cheers.
Thanks guys.
Cheers.
Thanks guys.
Cheers.
No special pads are needed. I use Hawk pads with my slotted and crossed drilled Powerstops. The rear calipers are stock on my 2000 SS and they are stamped PBR made in Australia . Check your rubber bushings for wear...if they look dry spray them with some warm soapy water and then test for the squeak.
hmm alright i shall give taht a shot.. provided it doesn't work.. would my next step be to get new pads? when i took off the wheel it didnt seem like the rear pads were worn down very much cuz they were roughly the same length as the back plate
