G8 dyno tune yields 34 rwhp and 29 rwtq (87 octane only)
Got to dyno a bone stock Pontiac G8 today. Nice car. Boy does GM cover their back-sides with all the timing reduction for temperature in coolant and IAT. Also very rich mixture.
Spent lots of time working on the tune since this customer would only run 87 octane. The results were very positive.
Baseline numbers were 279 rwhp, 299 rwtq
Tuned numbers were 313 rwhp, 328 rwtq
Because this tune was done on a Mustang dyno, we were also able to run the G8 on a 1/4 simulation.
Stock 1/4 mile dyno run: 13.44 @ 104 mph
Tuned 1/4 mile dyno run: 12.81 @ 109 mph
Tuned 1/4 mile dyno run with torque management removed: 12.49 @ 111 mph
Don't know how accurate the 1/4 mile dyno runs will be compared to the track, but a 13.44 @ 104 mph is not too far off of what stock G8s seem to be running. The owner plans on taking the car to the track soon so we'll have some real world results to back these up. Gotta love technology. We dropped nearly a second ET and we didn't have to turn a wrench.
I also made the AFM much more aggressive so the motor will cruise in 4 cylinder mode all the time cruising down the highway. I know this was good for a 2-3 mpg gain on my Suburban. I would expect similar gains on the G8. In this day of nearly $4 per gallon fuel, it's nice to gain over 30 rwhp and increase fuel economy at the same time.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Probably not a lot. The motor is only 10.4:1 and would probably make best power with around 26 degrees of timing. On 87 octane, we were logging an actual 23 degrees from 3000-3800 rpm, then pulling down to 20-21 degrees from 4000-5200, then ramping up to 23 degrees from 5400 rpm up. Not sure if that extra few degrees of timing with 93 octane would make much more power or not. I spent considerable timing tweaking the knock sensors to make sure they pulled timing for real knock, but desensitised them enough to keep them from jumping every time you moved the throttle (exageration). There is lots of power to be gained by carefully tuning the knock tables when trying to perfect an 87 octane tune.
__________________
The G8s come from the factory as 87 octane motors. The engine is basically the same as the 6.0L Vortech Max truck motor. That too runs on 87 octane only. The main spark tables allow for some headroom to run 93 octane, but the temperature timing retard protocol and oversensitivity of the knock sensors spoil most of the gains without a really good tune.
__________________
EFI Live version 7.5.
__________________
Totally bone stock. Needs cold air intake, headers, UD pulley and better intake manifold for some good gains. The stock cam is pretty tiny though. They cylinder heads are killer though. Love the 4 cylinder mode too.
__________________
