Few pics and video of my LS1/4L80E swapped 63 pick up
CoCouple pics of my buddy Mike driving my truck.. He has been there turning wrenchs from day one. He deserves a couple passes for sure..
Launch videos from yesterday:
http://73-ls1.com/63truck/track4-4/Launches.wmv
Some more video from today. Last one is of the 100 shot out of the hole and you can see it lift the right tire as well for a split second before it unloads the rear tire:
http://73-ls1.com/63truck/track4-4/sac4_5.wmv
I'll post some times after tomorrows runs..
Here is a pass for everyone to see. This was my best and only full N20 pass. It was only the first stage (100 shot) as I poped the second stage fuse as soon as I hit the button (Tried to spray 300). I did not spray out of the hole either, closer to the 60'. I could have made one more pass but I am pushing water from the radiator when on the unit. I think I have a small leak with a head gasket and the added cyl pressure on the bottle is pushing in to the the radiator causing the cap to lift slightly.
http://73-ls1.com/63truck/track4-4/100shot.wmv
I'll be pulling the motor out and apart just to do some looking at bearings, rings, rod bolts ect just to make sure everything looks ok. I put 20 passes on it this weekend, 13 last time, 30-40 dyno pulls and lots of tunning else where.
Here are all the passes we got on video..
Best pass on motor was 11.9x @ 113
Best (only decent N20 pass, lots of issues) was 11.28 @ 115mph spraying a 100 shot from the 60' mark. Tried grabing all 300 after the 1-2 shift but the fused poped in the direct port.
http://73-ls1.com/63truck/track4-4/s...08_low_res.wmv
Here is a detailed spread sheet showing all the times from this weekend. N20 passes are in Blue, only one was at full pressure. Red backrounded items are things that I feel were out of the norm and could be improved. IE the 11.2x N20 pass, I shortshifted 2-3 and only gained 19.x mph where even on the motor I'm gaining an average of 21.x on the back half.
http://73-ls1.com/63truck/track4-4/ET_Sheet_4_2008.xls
