James911
04-06-2008, 06:25 AM
Hi,
I have a couple of questions about the wiring of my SBC, because I do not know which cable is for which part at the engine.
I bought the car disassembled, therefore I have this problem.
It is a Chevy Impala year 1970 with a HEI-distributor vacuum , therefor I think it is one from 1975 to 1981 ??) and a Edelbrock carb 600 cfm, 4-Barrel with electro Joke
Here are some pics about, may be that helps:
http://s303.photobucket.com/albums/nn132/Impala-1970/Impala/
I think the following parts have to be connected:
alternator
starter
oil pressure sending unit
Hei
carb
How do I find out which cable is for what?
I found the following cables in under the hood, for which I measured the voltage and the resistance.
1. a single black cable, very long
Unfortunately formatting does not work for may tables, what I mean is I have three positions for the key OFF Run Start an then I write the result stuff I measured
Result from measuring
position of the key Off Run Starting
resistance to - Pol of Bat: no no connection no connection
resistance to + Pol of Bat: no connec no no
voltage + Pol of Bat: 17 V 0 0
voltage - Pol of Bat: 0 17 V 17 V
strange, depending on the key position its + or -
What is this cable for????
1. wiring harness contains three cables
longest cable, black
resistance to - Pol of Bat: no connec no connec no connec
resistance to + Pol of Bat: no connec no connec no
voltage + Pol of Bat: 0 V 0 0
voltage - Pol of Bat: 0 0 V 17 V
--> should be the cable for the starter, to give the starting signal
middle cabel (green black)
resistance to + Pol of Bat: no connec no no connec
voltage - Pol of Bat: 0 17 V 0 V
short cable (red)
resistance to + Pol of Bat: no connec no connec no connec
voltage + Pol of Bat: all three only leaking air current
voltage - Pol of Bat: all three only leaking air current
2. wiring harness:
red cable + and a connector that fits to the alternator ---> cable for alternator
Who can help me? all fuses are ok.
Thanks
James
alternator
starter
Hei
carb
short cable (red)
2. wiring harness:
Thanks
James
