Flywheel Problem
Old 04-06-2008, 08:52 AM
wajouba's Avatar
Thumbs down Flywheel Problem
I have my LS1 with Auto tranny on my 240sx S13, but Im facing a problem where my Starter is sometimes getting stuck... and it makes this sound (clinggggg) and then dosn't move... when I went under the car... I found out that my flywheel is actually moving... not in the regular circular motion... cause i can push it inward towards the Torque conv. so it ain't still... what could be the problem? Loose bolts? missing bolts? anyone had this problem before?
Old 04-06-2008, 10:40 PM
bczee's Avatar
Doesn't sound very good... looks like you need to remove the trans to see way the Flex plate is moving..!.. Did you seperate and joinned the Engine and Trans before you dropped it in ?
Is it the whole flex-plate or ust the ring gear that is moving? The Flex-Plate should not be moving at all in a North/South movement !
Old 04-28-2008, 03:10 PM
wajouba's Avatar
Can anyone give me the right sizes of the Flywheel bolts? The inner ones and outter ones...
