Wiring issue with installing pacesetter long tubes
I'm in the proces of installing the passenger side header and have no clearance with the wiring harness? Any ideas for re-routing this away from the header?
I did what I could to keep them away from the headers when I did my install. The factory heat shielding **** did a good job, maybe too good. It stayed completely intact while the conduit and a ground wire inside of it melted.
I extended the wiring 12-14 inches and ran it forward, down, then through the engine mount to keep it away from everything. It's a simple and effective job.
