Question about the control arm relocation bracket
Old 04-06-2008, 02:02 PM
bigfatls6's Avatar
Default Question about the control arm relocation bracket
I got the bolt on BMR relocation brackets and I am wondering which hole to mount the control arm in in the rear? It has two holes one is higher than the other. Right now I have it in the lower hole. Does this affect ride hiedth? Also my car has not been lowered. does it affect traction if you have it in the top or bottom hole?
Old 04-06-2008, 03:28 PM
mchdg86's Avatar
I just got done putting the weld-on versions on my car and have them in the lower hole. I have always heard the lowest one is the better one to use and it didn't affect my ride height either.
Old 04-06-2008, 05:05 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
The relocation brackets will not effect vehicle ride height. Our relocation brackets also have the control arm holes placed on an arch so there is no need for a set of adj. lower control arms to maintain proper wheel alignment. If you are looking for more traction from a stop you want the lower control arm in the lowest hole in the relocation brackets....
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 04-06-2008, 08:12 PM
Moderator
jimmyblue's Avatar
Use the lowest and only back off if you get brake hop on hard
stopping. Otherwise it's all bonus. But find a place to test for
brake hop safely just so it doesn't come as an inopportune
surprise later.
Quick Reply: Question about the control arm relocation bracket
