cam swap done!
Old 04-06-2008, 06:49 PM
2000NavyZ's Avatar
Default cam swap done!
after 18 hours or so of working its done. I replaced the oil pump,timing chain, cam, lifters, valve seals (they were almost all junk), and put on a ls6 intake. Everything went pretty smoothly until we dropped a bolt into the oil pan, but after an hour and a half of ****** around we got it out and everything back into place. It pulls pretty fricken hard all the way to the rev limiter.... ill post some sound clips tomorrow, im way to spent to even get off my ***... it was worth the work though!
Old 04-06-2008, 06:54 PM
jetlag's Avatar
Any pictures of the install? what are your cam specs?
Good job doing it yourself! I just bought a 228/232 cam, but have to wait til I get the rest of the parts also.
Old 04-06-2008, 06:58 PM
Apollo0526's Avatar
Awesome job!! Hope to get some pics and sound clips. i have to post mine up here too.
Old 04-06-2008, 07:04 PM
2000NavyZ's Avatar
i didnt take any pics during it cause i got to into it and to lazy to go grab my camera, the cam specs are 232/226 on a 110. We used the dowel method in to the two holes right next to the cam and that worked amazing! for 2$ you couldnt beat it. sound clips tomorrow!
Old 04-07-2008, 07:08 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Get a tune done.
Old 04-07-2008, 09:12 AM
kratos2250's Avatar
Cool I just installed the tourquer v2 in my camaro and I bought the 5/16 steel rods, and could olny get them half way in so I took my chances and swaped the cams. Got lucky and no lifters dropped
Old 04-07-2008, 09:22 AM
andrew69_04's Avatar
Umm....Why did you use dowels if you changed the lifters??
Old 04-07-2008, 09:24 AM
INMY01TA's Avatar
Ya good point.
Old 04-07-2008, 09:40 AM
bsf
bsf's Avatar
Maybe he wanted to guard against a brief moment of stupidity like I experienced when I pulled my cam. I cannot count to 16. I start getting confused around 14. Start pulling my cam out and hear “clunk clank clunk”. Dohhhh!
Good job 2000NavyZ. Feels good to know you did your own work does it not?
Old 04-07-2008, 09:59 AM
Internet Mechanic
Ive heard people having issues with that, but oil and working the cam helps. The russian roullette method works but like said, it takes that one time.
Old 04-07-2008, 02:35 PM
my question was, if he was changing lifters wouldnt the heads be off and there be absolutely no reason to even need dowels? unless he swaped in the cam, then pulled the heads.
Did you do any headwork while you had the heads off?
Old 04-07-2008, 03:02 PM
bsf
bsf's Avatar
my question was, if he was changing lifters wouldnt the heads be off and there be absolutely no reason to even need dowels? unless he swaped in the cam, then pulled the heads...
Correct.
I accidently left one lifter in the hole. It did not come out with the retainer, and I did not notice.
Old 04-07-2008, 04:58 PM
Camaro396's Avatar
Good work get a idle video up! I think dropping a bolt in the pan usually comes standard when doing cam swaps on these cars.
Old 04-07-2008, 10:58 PM
2000NavyZ's Avatar
idk why i put lifters, we didnt change those
Old 04-09-2008, 07:56 AM
Camaro396's Avatar
Video?
Old 04-10-2008, 07:18 AM
kratos2250's Avatar
Don't have a video But I do have dyno #'s 376rwhp/353rwtq
Old 04-10-2008, 07:29 AM
are those numbers somewhat low? my buddys 01 SS has a 224/224 with abotu a .580 lift on a 114, ps LT's, ory, and a slp catback, lid, and he put down 395/387. with the highewr duration i would think those numbers should be higher, but you also have a stall which might contribute.
Old 04-10-2008, 10:06 AM
white99's Avatar
Magnet finders are your best friend for times like that. Nice job though!
Old 04-10-2008, 09:11 PM
PewterMNZ's Avatar
In your other post, you said the cam you installed was the TR 230. those specs are 230/224 .575/.563 111 LSA. did you get a custom grind on top of the TR 230?
