Cam install tips...
Old 04-07-2008, 12:15 AM
foshizl's Avatar
Exclamation Cam install tips...
I recently installed a cam in my 2000 camaro z28 and figured I would post up a couple things, that may come in handy for someone else embarking on this adventure... two things:
1. When taking off the oil pickup line off the oil pump shove a rag or something in the oil pan to catch the bolt if it drops. I was lucky and the bolt dropped but got stuck on the first baffle in the pan. So we just pulled it out with a magnet.
2. When reinstalling the oil pump its much easier to take off the cover and gears of the oil pump, to see/make sure the O-ring goes in correctly and doesnt get pinched. We had put the car all back together and fired it up and ZERO oil pressure, tore it back down and the o-ring was pinched... cost us about another 3 hours of work.
Thats pretty much it, other than that the install went good no major problems. Just wanted to post this up as tips for anyone doing this.
Old 04-07-2008, 12:26 AM
mrhzk35404's Avatar
For the oil pump bolt, I took mine almost all the way out and then got a small zip tie and wrapped it around the thread and then took the bolt the rest of the way out. I used a piece of mechanics wire to install the bolt.
Old 04-07-2008, 12:52 AM
BatmobileSS's Avatar
I'm getting ready for my install next weekend if everything goes as planned. Tips are a good thing for me to read right now. Keep them coming.
Old 04-07-2008, 12:57 AM
droptopT/A's Avatar
i need help right khow im in the middle of my camswap but i cant get the lifters to stay up to put the wooden dowel
Old 04-07-2008, 12:59 AM
Emoney97ss's Avatar
you should have all the valve train stuff out as rockers and pushrods... then you have to spin it as you slide the dowel in....
Old 04-07-2008, 01:01 AM
droptopT/A's Avatar
yeah i got the rockers and push rods out i even removed the spark plugs already
Old 04-07-2008, 07:04 AM
Internet Mechanic
BlackScreaminMachine's Avatar
buy a set of aluminum rods, should be 5/16" inch, they work the best for holding lifters. Also using a proper puller and installed on the pulley will ensure you dont snap bolt.
Old 04-07-2008, 11:38 AM
Fratsit's Avatar
Some pics of the oil pump for ya.....
They are a little big once you click on them. I agree with the OP....taking the pump apart and them installing it worked great for me. I attempted to center the housing on the crank using feeler gages as recommended.
R/
Frat
Old 04-07-2008, 04:40 PM
foshizl's Avatar
droptopT/A: I used jpr tools to hold the lifters off the cam, mine slid right in all the way to the back... without turning hmmm. yeah you might want to try the metal dowel.
