Check my shopping list please-
Old 04-07-2008, 09:37 AM
fstphx's Avatar
Default Check my shopping list please-
I get back from Germany in a week (On Business) and want to have everything gathered (preferably delivered) for my heads and Cam swap to ensure as little downtime as possible.
Does it look like I am missing anything? Would you change anything- This is my first build, hoping it goes well.
I have a tuner lined up as well as a top exhaust guy- I have debated going custom duals all the way out(not a fan of dumped), with or without cats (not too concerned with emissions, just dont want hassled if hi-flow cats wont hurt)
The motor will see some spray again ~150 shot
From Texas-Speed.com
Pacesetter Headers & TSP Off RoadY Pipe Combo Item# 25-225x/OffRoad
$509.99
ARP 12-Point Head Stud Kit , Pre-2004 Blocks! Item# 46-234-4316
$279.99
ARP Harmonic Balancer Bolt Item# 46-234-2503
$27.99
GM LS1 Water Pump Gasket Set Item# 28-12588372
$9.18
Cometic LS1 MLS Head Gaskets, Pair, 3.910" Bore Item# 202-391
$149.98
Gasket Thickness | .040"
Rollmaster Double-Roller Adjustable Timing Set Item# 11-1140
$117.99 $117.99
*Added
TSP Ported LS6 Oil Pump
Item#:25-12586665M
$139.99
GM LS1/LS2/LS6 Timing Cover Gasket
Item#:28-12574294
$19.99
Subtotal: $1255.10
Total Items: 8
Already Have-
Comp Cam- 238/242 605/610 113 lsa
Speed Inc's R.G.R st2 heads.
2.02 intake and 1.59 exhaust.
921 springs.
They have about 1500 miles on them but they are completely redone.
New hardened pushrods from comp included with the heads.
RGR Performance Heads
Excellent cylinder heads that are fully ported for us locally. Highest quality Comp springs/retainers and Ferrea valves are used. A great option for those who don't need the big name. You will not be compromising quality or performance with these cylinder heads.
Old 04-07-2008, 10:46 AM
oldmanwinter's Avatar
How about an oil pump and timing cover seal and gasket. Also, either a longer balancer bolt or an install tool. Adjustable pushrod length checker and a set of light checker springs
Old 04-07-2008, 10:58 AM
fstphx's Avatar
Thanks for the reply-
Oil pump- LS6 or i see they have a TSP ported LS6 for an extra 10PSI...
recomendations?
I am doing it with a guy that has done several LS motors so he should have all the checkers and install stuff-
Old 04-07-2008, 11:38 AM
Restricted User
socmguy's Avatar
don't forget a new OP pickup tube O ring if you do go w/ an oil pump. You should also replace your crank snout gasket too. It's in the center of the front cover.
Old 04-07-2008, 12:40 PM
Kingc8r's Avatar
Looks like a nice list...and do what the others have suggested
Old 04-07-2008, 12:59 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Aside from...
Oil + Filter; for 2 oil changes,
Brake Clean
RTV
Blue Loctite
Fuel and Air Filter service
Gaskets for the header or Y pipe
It looks pretty good, please not I had this post written but for got to click the button lol
Old 04-07-2008, 01:00 PM
Bill Bowling's Avatar
Possible valve cover gaskets. New NGK TR6 plugs. ARP lube.
Good luck.
Bill
Old 04-07-2008, 03:05 PM
bsf
bsf's Avatar
Assembly lube
ETA
Also consider doing poly motor mounts while the headers/manifolds are off. I painted the clamshells while I had access to them. In fact, I painted a ton of stuff while it was removed.
Old 04-07-2008, 04:07 PM
fstphx's Avatar
Thanks guys- reminded me of a few things-
I think i have been talked into stepping down on the cam a bit- something slightly more streetable. Also ordering GM MLS instead of cometic.
