Advice on Cams!
Advice on Cams!
I would like to get some cams....I WANT A DAILY DRIVER CAM!!!!!! I DONT WANT A MONSTOROUS CAM! I am not looking for a huge gain i just want to have get to the 12's with out getting a stall or rear gears.......well i was on craigslist and i found someone with this.....if you have any opinions on what i should be looking for just tell me..... I dont want a required tune cam.... you know.... i will tune my car.... but i dont want to have to do it right after!
Grind Number# HR-287-CSB
Valve Setting:
IN./Hyd.
EX./Hyd.
RPM Operating Range:
1800 to 6600
Duration:
Advertised IN./.287 EX./.287
@.050" IN./224 EX./224
Valve Lift:
1.7 Rocker: IN./.545 EX./.545
Springs: LS1
Lobe Sep. Angle:
114
Valve Setting:
IN./Hyd.
EX./Hyd.
1800 to 6600
Duration:
Valve Lift:
Springs: LS1
Lobe Sep. Angle:
114
You want to get some cams? Buy a honda. If you want A cam, then your good to go with what you have
Id look into a 224 or so. They are a good DD cam. The only thing is your going to want a stall with whatever cam you go with.
