355 questions that need answers to them
Old 04-07-2008, 10:27 PM
mean_greenZ's Avatar
Default 355 questions that need answers to them
ooookay... im thinking of a 355 build idk if it will be forged or not. that stuff is expensive. anyway what is a good grind cam for a 355 to make good power through the entire rpm range not just top end? it is a DD and will continue to be. i plan on building the trans myself and putting in a 3000-3200 yank converter. are the xfi cams any good? if so which one? also has anyone on here run the edelbrock lt4 heads? they any good?
Old 04-08-2008, 08:03 PM
ok guess no one knows
Old 04-08-2008, 08:36 PM
chavez885's Avatar
Edlelbrock LT4 heads blow. You're better off with stock ported heads then wasting money on those. Advanced induction my first recommendation. Up to you on a forged rotating assembly, but honestly a custom grind is your BEST choice. Advanced induction does those as well. Loyd Elliot is another option.
Old 04-08-2008, 08:54 PM
ok thanks. ive just never seen anyone run those heads and didnt know if they were good. LE2 is probably my best bet
Quick Reply: 355 questions that need answers to them
