got cam questions
got cam questions
i am installing this cam 290/ 307, Lift .510/ .540. and i was wondering if i will have to change my valvetrain or can i run my stock ones. and will my computer be ok for a lil while but before it gets reflashed. basically i am putting this cam on a stock motor and i was wondering if it is going to run right and be worth it
Read over my cam sticky at the top of the forum. It will explain what valvetrain components will need to be replaced. You cannot install a new camshaft and not do valvetrain unless you want to end up putting a couple grand into your motor after you screw everything up. That cam you are talking about is the cc306 and you may want to read up on that before you install it assuming your car is stock. Read that sticky over real good.
