smoking!!! A little help please!
So I decided to get a set of Harland sharp 1.8's, Patriot Golds spring kit and 36lb injectors. I get them installed and get a re-tune. On my way home my car is smoking BAD. I let the car cool off and as I'm putting it in the garage it is still smoking! bad. Oil smoke. I call the installer and tell them I think a valve seal was not installed right because I'm burning oil. I take it in and they say that all 4 plugs on the passenger side are black and say its my o2 sensor on the passenger side is the culprit. I get charged for the parts and labor to re inspect everything cause they said it turned out not to be an installation issue on their part. I said cool. Now this weekend I take the car out again and guess what? my **** is still smoking at times, so I pull a plug the first one on the passenger side . so to my surprise I see that my plug has a lot of soot and oil on oothe threads of the plug (closest to the electode). so I call my installer and they tell me now its gonna be the valve guides!
but only on the passenger side??!! what gives?
can a simple valve seal install ruin the valve guides?
I doubt it but can it happen?
what can be maybe pushing the seals up, my melling oil pump with castrol 0-30?
I am pissed and puzzled!
any help will be greatly appreciated!
I will be posting pics of the sparkplugs tomorrow.
thanks
thanks
that's the thing, I wouldn't mind it if someone said "hey Zeke listen, we screwed up that install, I'm gonna get it right this time". now I paid for an 02 sensor and an extension I didn't need, labor to recheck the install, and 4 plugs that were supposedly damaged by the o2 sensor. I just don't get it!
But anyone else have an idea?
First of all, from your description, you're isntaller/tuner doesn't have a clue - so step number one, don't take it there anymore. Find someone who knows what they're doing and get it checked. It sure seems like the vlave seals and or tune are screwed up, most of all it is runnign rich and if they did the injector tune wrong (very likely) then that is the cause.
Well I took out the other side today and they were nice and clean!
So I took out the passengerside this morning and this is what I found, I apoligize for the quality of the pics but I could not get my camera to focus in any settings! but you can tell the oilish film on the threads and the dark spots on the electrode and Porcelain. Please let me know what you guys think my problem may be, the car never had this problem. The problem came when I upgraded springs to patriot golds,Harland Sharp 1.8's and lucas injectors(used by a respectable member of the forum)36lb'ers and after about 150 miles of use since the install and retune.
burn 'em back to a nice dull/light grey color with a blowtorch to save the spark plugs. regap when done.
great!
now take the car to someone who is more knowledgeable about what is going on because the three strike policy shouldnt end up with a BOOM! of your motor....
great!
Either the valve seals were not pushed all the way and seated on the little spring that is on the base of the seal or your IFR table in your tune was not calibrated correctly.
If it were injectors why is only one side effected?
Find another shop, document everything, small claims court is going to be an option for you. The shop needs to eat its mistake and wont admit they made one.
Thats just typical. Most so called mechs havent finshed 6th grade. Reputable shops are hard to come by. I see adds in the paper all day long that advertise for 15hr for shop help. You really want some kid who didn get through high school working on your car?
Or they worked for Jiffy lube for 2 years and now they're a mechanic. I have had friends bullshit thier way into the postion and last for years at the same place because the owner didnt know a thing. This guy built a 327 for his Chevy 2 and it wouldnt even turn over but yet there he was working on the company fleet.
Long winded moral of the story, find another shop.
Im not saying that oil cant still be seeping through somewhere. I am saying that 968 constant during normal driving is wrong and too rich.
I will keep an eye out for that while Im driving, on the IFR table does it separate Left to Right banks, Brad?
the reason I ask is because the frivers side sparkplugs are burning normal, the porcelain is nice and white!
I really appreciate you guys time to helping me solve this issue!!
