Western Members - rubbing on right turns? cornering!
ae13291
04-08-2008, 01:40 AM
hey guys, well currently in the back of my car has a BMR adjustable PHB,BMR LCA, tokico shocks, and vogtland springs, and 255/50/16's i have my PHB adjusted already and its pretty straight now, but i noticed when i corner a bit hard in a right turn i can hear some type of rubbing from the rear! what would you guys think it it? maybe the nut on the PHB came loose? i am going to buy a upgraded rear swaybar soon maybe 23mm will that fix my problem??
djsanchez2
04-08-2008, 02:18 AM
Check for signs of rubbing. Tryo to find the source of the rubbing before you waste money on the wrong "fix".
I had that issue twice. The first time it was the passenger tire, the second time it was the tire on the inner fender. (bet it has 315's lol)
m6ttop
04-08-2008, 02:24 AM
double check your PHB. then find the rub spot and hammer away
BAD-GTO
04-08-2008, 03:12 AM
I dont see how you can rub with only 255's? You wouldnt happen to have GTO rear fenders on your Camaro... would yoU??:engarde:
camarojunky74
04-08-2008, 11:17 AM
lol, only 255's and rubbing, there has to be a problem with your adj maybe its inner fender and just havent noticed yet, you need to go down there and look, then get some real tires on that car. lol
ae13291
04-08-2008, 05:06 PM
yea i have some 10 spokes with 275's in my backyard! but im going to my buddys shop now, maybe get my car on a lift to check it out!
camarojunky74
04-08-2008, 05:21 PM
make sure its a drive on lift, a 2 post wouldnt do any good really.
trans am you lose
04-08-2008, 05:31 PM
My car used to rub in hard turns heading up to big bear but i had 295 30 19's on the back at the time. just check for the rub mark and smash it in, but it sure does seem strange that it would do that with the smaller size of these tires.
ae13291
04-08-2008, 09:57 PM
i just saw my problem, its a very very light rub on the bump stop on the left rear wheel! its very light, i can only tell since the wheel is a little clean! but i think it may be my panhard bar but it looks pretty even! i may just move that wheel a tiny bit out to solve the problem!
m6ttop
04-09-2008, 10:53 AM
cut the bumpstops!!!
Datzneat
04-09-2008, 12:25 PM
If you're not rubbing you're not driving fast enough. :drive:
ae13291
04-09-2008, 02:33 PM
im already taken right hand turns at like 40 2nd gear on throttle, i may just leave this alone until i install my other wheels, and i want to get my swaybar soon too!
Soul TKR
04-09-2008, 02:45 PM
http://www.ls2.com/forums/showthread.php?s=&threadid=223590
djsanchez2
04-09-2008, 03:13 PM
Good deal. See you didn't have to go spending money for nothing. It's always the simplest of things that seem to go wrong.
ae13291
perfect!! thanks dude, if the problem gets worse i will be doing this! i will probobly remove that spacer just for more travel too! thanks
Soul TKR
04-09-2008, 04:38 PM
no problem ;) hope it helps :drive:
LT Chevyboy
04-09-2008, 06:30 PM
Not sure why you'd be rubbing with such a small rear tire. I'm lowered, and have 315's in the back. I had to roll finders and hammer on the inside well though. But even prior to that, bumpstops never got in the way. Now, I don't scrape anywhere.
Maybe panhard adjusments are off? Just alittle confused why you'd scrape with such a small tire, and I'm assuming stock height??
ae13291
04-10-2008, 02:20 PM
running lowered with vogland springs! i did not have this problem till i had to readjust the PHB to the drop level!
MrElectric03
04-11-2008, 10:09 PM
Mine rubs on hard right turns too...but im lowered on 315s with the stock panhard rod.
ae13291
04-11-2008, 10:51 PM
i guess ill take it a bit easy on turning, but mine is such a very light rubb, i mean i can barely notice
m6ttop
04-12-2008, 11:40 AM
couldnt fix it yet?
ae13291
04-12-2008, 05:27 PM
lol not yet! maybe after it bothers me alot
m6ttop
04-14-2008, 09:55 PM
when u adjust ur phb where is the jack or jackstands?
ae13291
04-16-2008, 01:21 AM
i had them under on the differntial right next to the swaybar ends
Soul TKR
04-16-2008, 01:25 AM
next time you take off your tire... look for the rub spot... then bang the shit out of it with a sledge!
m6ttop
04-16-2008, 12:16 PM
theyre supposed to be on the "frame rail" right before the RCA.use the jack to lift the axle if u have to.Otherwise it will bind up
ae13291
04-16-2008, 03:58 PM
yea i know what u mean but i wanted to have the rear loaded so its adjusted right! but i think i may be rubbing on the outer parts not exactly on the bump stops! but so far it hasent rubbed since i have the rear 10 spokes on and i cant corner any more with those tires that arent the best, so i just have been doing some burnouts lol,
