Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thumpr Retro-fit cams
Old 04-08-2008, 10:50 AM
F-Body Lover's Avatar
Default Thumpr Retro-fit cams
I think everybody saw the retro-fit cams that Comp cams offers but I was thinking of putting a retro-fit hydraulic roller in a roller engine instead of hydraulic flat,will it work? I mean those cams were made to fit a roller cam in hydraulic flat engine but will it work fine if I fit the same cam in a roller engine? I found this note in Summit (Notes: Designed for engines originally equipped with flat tappet camshaft.) so does any one did this before?
Old 04-08-2008, 08:27 PM
jmm98LS1's Avatar
The retro fit camshafts do not have a step on the end of the cam for a retainer plate.....you'd have to run a cam button to keep the cam in the block. Otherwise it should work just fine.
Old 04-08-2008, 08:50 PM
so all I need is a cam button? nothing else?what about the lifters? do I need to use those vertical locking or OEM style will work?
Old 04-09-2008, 02:54 AM
1997bird's Avatar
You can run your OEM style lifters if you have the link bars and retaining spider. You will also need a 85' & earlier timing chain.
Old 04-09-2008, 06:57 AM
I will get timing gear for super charge noise ,so 85 and earlier timing chain is a must and cam button and use the OEM roller lifters thats all?
Quick Reply: Thumpr Retro-fit cams
