At what time do you need aftermarket axles per NHRA rules?
Old 07-29-2003, 03:22 PM
JimmyKash's Avatar
Default At what time do you need aftermarket axles per NHRA rules?
Currently i have 30spline non c-clip type axles, is there an ET where i need aftermarket ones?
Old 07-29-2003, 11:41 PM
DONAIMIAN's Avatar
Default Re: At what time do you need aftermarket axles per NHRA rules?
I think the rule your talking about is having c-cplis, saying that you cant use them. Someone else might have more info about it
Old 07-30-2003, 11:20 AM
Assassin's Avatar
if your running slicks, you need c clip eliminators, a drive shaft hoop, and extended studs to clear the width of the stud past the wheel nut, I dont beleive the spline matters at all, but I could be mistaken
Old 07-30-2003, 04:53 PM
JimmyKash's Avatar
Ok cool.....so there is no NHRA approved axle i "have to have?" The stockers will be fine as long as i have the studs. Cool
Old 07-31-2003, 06:10 AM
Fireball's Avatar
http://www.nhra.com/tech_specs/ETQuickRef.html
Need aftermarket axles at 10.99
Old 07-31-2003, 09:11 AM
JimmyKash's Avatar
see i knew it
Quick Reply: At what time do you need aftermarket axles per NHRA rules?
