flycutting
Old 04-08-2008, 01:32 PM
SSstud's Avatar
Default flycutting
just want to see how many of you flycut when you went with your big cam. ms4, trex, vindicator...was it worth it? necessary?
Old 04-08-2008, 01:51 PM
MLP00Z28's Avatar
Trex and MS4 are not needed, even though I've seen some pistons that had valve marks, if your engine is out of the car and disassembled do it just for insurance. I personally had a trex put with stock shortblock and never left a mark ok the pistons, after bout a few months I bought some wiseco with valve relief pistons.
Get a junk head and flycutting tools, they're pretty cheap and will save you some worries.
Old 04-08-2008, 02:45 PM
ArklaTexan's Avatar
MegaDeath here, no flycutting needed.
Old 04-08-2008, 04:32 PM
regorih383's Avatar
What heads, were they milled, and what head gasket????? Specs on the cam???
Old 04-08-2008, 04:34 PM
smokinponcho73's Avatar
what about the ms4 any body see any problems with these
Old 04-08-2008, 05:05 PM
ArklaTexan's Avatar
Cometic Gasket .04 or .4 whatever, Patriot LS6 Stage II 59cc Heads
No they were not milled the used welded chambers. The new casting mill i believe.
Cam 244/242 .612/.610 112 lsa
Old 04-08-2008, 08:23 PM
GuitsBoy's Avatar
Smallish T2 cam, but heads milled .040. Easy to do, and well worth it. My cam has room to spare should I ever upgrade.
