Ron Davis Racing radiator w/internal oil cooler for fbodys
Old 04-08-2008, 04:57 PM
99blancoSS's Avatar
Default Ron Davis Racing radiator w/internal oil cooler for fbodys
You FI guys might appreciate this more. Ron Davis Fbody Radiator with internal oil cooler. Ron Davis Racing is the king of the hill. This is designed to fit the fbody. I am running an introductory of $780 plus freight. The price will then go to $840
https://ls1tech.com/forums/sponsor-group-purchases/897882-ron-davis-racing-radiator-gp.html
The rad without oil cooler option is $680 and will go up as well
Part Number 11-16CA0002
Old 04-08-2008, 05:03 PM
sdbrown84's Avatar
We have one on my Dad's GN. Awesome radiators.
Old 04-08-2008, 05:05 PM
2000 Tran Zam's Avatar
Whats the difference between one with an oil cooler and one with out? How much different would temps be?
Old 04-08-2008, 05:21 PM
Originally Posted by 99blancoSS
Those were results someone posted with an oil cooler only. The Ron Davis radiator alone will make it run cooler to begin with so you really cant give an honest answer here but I would say in my opinion it would be fairly better results than those guys.
Do they make oil cooler attachments for products like griffin radiators?
Only reason I ask is cause my turbo is like 2 inches from the radiator and it works pretty well but if I start to overheat (just got motor back in car and idling today) I wanted to see what other options there were besides ripping the headers apart and physically moving the turbo back.
Im also running an evans coolant pump setup.
Old 04-08-2008, 05:24 PM
99blancoSS's Avatar
Ok, got the low down: The radiator itself wiill drop temps 20%. The oil cooler will drop the oil temp 30*-40* This is sufficient for most drag racers.
They do have an option to drop the oil temp 100* for the serious hardcore guys. A remote cooler and then you would order the radiator without the cooler option. This is more for the long open road and endurance racing guys. THe cooler can be used for various things not just engine oil. They have two sizes of it.
Old 04-08-2008, 05:27 PM
99blancoSS's Avatar
In-line Dual 14 Plate Heat Exchanger
Designed to be installed in-line between the radiator and water pump.
Doesnt sound like a good option for you, but I'm sure you could plumb it.
Quick Reply: Ron Davis Racing radiator w/internal oil cooler for fbodys
