Front sway bar delete?
I am trying to cut as much weight as possible because I really cant afford to build my engine right now and am still trying to improve my times. I have read alot about the front sway bar delete and was considering doing it. I was wondering if anyone on here has done it and can tell me more about it, I know its going to chew up my front tires but at what rate? Is there anything else I can do to cut weight thats not completly gutting my car?( I do still want it to be kind of a street car)
any information you can give me will be greatly appreciated, thanks
I took mine off, its a just a weekend warrior, and strip car you will be fine IMO. I drove the track that was 120 miles away and i no problems. Actually when i disconnected and left in the car i pulled the front wheels off the ground. Now i got it out of the car with UMI k-member and front lcas installed, it should really pull the wheels now.
Here we go again... the start of another Drag car guy vs corner carving guy thread..
https://ls1tech.com/forums/suspension-brakes/682351-street-driving-w-out-front-swaybar.html
had mine off for over 30k miles. no noticeable difference on tire wear after an alignment. it will let the car raise up about 1/2" or so. not to great on handling. right now i personally wouldn't take it off for weight savings. but then again i haven't gotten to wanting to reduce weight.
https://ls1tech.com/forums/showthread.php?t=682351
Haha thats what I was thinking I took mine off and I drive it on the weekends and at the strip every now and then. Noticed very little difference with it off. It does remove some weight for sure.
and i cant get to my o2 sensor bcuz my jack dosent go high enough and that has to be changed. then i just have to get my manifold on and my fuel pump in and get my car tuned again from you guys, then i'll race you.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Had mine off once for 2 days..waiting for new Hotchkiss brackets...will never drive it again without a front swaybar....never...handled crappy..and bouncy/unstable around turns.........
This thread is a little better https://ls1tech.com/forums/showthrea...front+removing
That thread above is completely useless. Just a bunch of people saying do it or don't do it. Though I would recommend to noobs to look at Foxtron's or Sam's advice over all the others in there, or anyone who understands suspension over the people who say "I do it and haven't had any problems"....
