broken harmonic balancer??
Old 04-08-2008, 09:48 PM
candlelit's Avatar
Default broken harmonic balancer??
Tell me what you guys think about this...
We pulled this motor out for an engine swap and were going to re-use this until we noticed the problem. What do I do now???
Old 04-09-2008, 07:15 AM
fortmyerspolice's Avatar
Get an underdrive, I wouldn't use that if I were you
Old 04-09-2008, 07:36 AM
vettenuts's Avatar
Almost looks like someone tried to pull it once, get a new one especially since its an easy swap right now. New front seal too.
Old 04-09-2008, 01:36 PM
candlelit's Avatar
do I need to get an aftermarket underdrive? or what do you guys recommend doing? I'm kinda on a budget here...
Old 04-09-2008, 01:45 PM
rdmelton's Avatar
If you want to go the budget route, I have a used stock balancer & belts that are in good condition. PM me if you are interested.
Old 04-11-2008, 12:31 AM
candlelit's Avatar
rdmelton... thinking about it, thanks.
though I'm thinking of getting a U/D system. I'll be small cam, turbo, & DD setup. does anyone know if I will benefit of an aftermarket or stay stock? I don't see the need to pick up an extra 5 hp, if any, for $170. why would I want to go aftermarket?
Old 04-11-2008, 07:23 AM
Pulley won't make much of a difference on a dyno, it will at the track though.
Old 04-11-2008, 08:03 AM
vettenuts's Avatar
With the motor out of the car, a Powerbond is keyed and you can use the ATI kit to pin the crank.
