Let's see how much you know about F-bodies
OK. this isn't a game of trivia. It's just something I needed some help with to figure out to save me some time.
Does anyone know what size and pitch of the shifter mounting bolts are for a f-body M6 is ? .......... Last time I installed my Pro 5.0 I found that one of the bolt holes was striped .... So, this week since I got some time off I'm gonna take it out and throw a heli-coil in and fix er up, along with a few other things. I would like to get the heli-coil without having to take off the shifter and measure it. Just tryin to save some time.
Also, anyone got any good tricks to change plugs without having to jack up the car to get at the #8 plug ? And without pullin down the K member ? Not assuming to many good answers on this one, but if anyone has one , I;m sure everyone would like to know.
Thanks
Thanks
1 Post
use 2 people for the #8 plug! one from bottom to guide you and the guy from top must due it blindly! the easiest way is to remove the pass coil pack or just loosen it and move it up and out the way
There are two ways to do this:
1. Remove radio and punch through firewall.
2. Trade it in on one with less mileage
That one isn't as bad as it looks. Like brad8266 said take the coil bracket off and its right there.
I have no idea why i didn't think of pullin the coil packs... Actually, pullin the valve cover might gimme some extra clearence too. Take all of five mins. Thanks.
Now if I could just figure out what happened to my sig ............
