Pontiac GTO 2004-2006 The Modern Goat
Rear Springs
Old 04-09-2008, 01:24 AM
BlueBandit's Avatar
Cool Rear Springs
hey guys listen im trying to gett a better stance with my gto.. tired of it sagging when i power brake it.. where can i go to get stiffer springs and shocks besides pedders??? does anyone else offer stiffer springs that DO NOT lower my car??? along with shocks too..
Old 04-09-2008, 02:50 AM
PapaSmurf2005's Avatar
What's wrong with Pedders?
Old 04-09-2008, 12:21 PM
batboy's Avatar
Hard to beat Pedders zero drop rear springs (I have +5/16" drag springs, but the zero drop are very nice too). They are about 50% stiffer than the stockers. I also have the Pedders GSR shocks. Nice pretty red.
Old 04-09-2008, 01:20 PM
freelancer's Avatar
I've got zero drop King spings on mine with drag bags. Wheel hop is still there if thats what your trying to get rid of.
Old 04-09-2008, 06:17 PM
B4Cya's Avatar
I've got drag bags in an otherwise stock suspension and they helped w/wheel hop quite a bit. It's also nice you can adjust them to figure out what you like the look and feel of. Also cheap and easy to install.
Old 04-09-2008, 07:02 PM
batboy's Avatar
I wanted to run 275-40-17 Mickey Thompson ET Street drag radial tires, so that's why I went with the taller drag springs. The Zero drop Pedders springs will work fine for stock size tires and Nitto 275-40-17 drag radials (they run narrower).
I had a PM asking about the half shafts. They are custom made by a guy I know that has his own company. PM me if you want info about how to contact him. He uses Porsche 930 CV joints with chrome moly CV cages and hardened races. The 930 joints are thicker than the stock CVs and distribute the load over a wider area. The axles are made from tough 4340 material. They also come with a new set of longer 12.9 grade bolts. The red power coat was sort of a one off, but who knows, you might be able to talk him into powder coating more.
Old 04-09-2008, 09:26 PM
What does this have to do with the thread? It's no secrete, go to LS1GTO.com and do a search about it.
Old 04-09-2008, 09:43 PM
batboy's Avatar
What does your post have to do with the thread? Take a chill pill. I posted a pic of springs and shocks and then got a PM asking about the axles. I figured I'd post the info in case someone else was curious. Oh yeah, it's spelled "secret".
Old 04-09-2008, 09:49 PM
I just like being an *** sometimes, that's all
Old 04-10-2008, 01:21 PM
Rob
Rob's Avatar
I'm running this setup also, but with Koni adjustables. Wheel hop is at a minimum with street tires and about non existent with drag radials.
Very nice combo, IMHO.
Old 04-10-2008, 04:53 PM
my first GTO's Avatar
PEDDERS All the way.......Frank
Old 04-13-2008, 08:52 PM
PokeyGTO's Avatar
Other then pedders I only know of King and Lovells for the GTO that dont lower the car.
Old 04-13-2008, 09:19 PM
LSX Performance's Avatar
I had King springs on my 04 GTO and Pedders on my 06 GTO. Didnt have problems with either. I'd go with the Pedders since they are easy to get.
Old 04-14-2008, 12:14 PM
JUDGEMENT's Avatar
I have the king 0 drop rear springs and I love them. It evens the stance out perfectly i.e same distance from fender to tire.
Old 04-14-2008, 10:42 PM
b15nut's Avatar
Lovells are cheaper than Pedders if that is part of your concern. From what I have heard Lovells was just purchased by Noltec.
Old 04-14-2008, 10:44 PM
b15nut's Avatar
Just be glad his avatar isnt the same as on our local site GHEY!!
Old 04-15-2008, 11:06 AM
AlexLs1's Avatar
I've heard nothing but good things about Pedders, I witnessed a 28 point inspection at Precision Motorsport and the rep was so knowledgeable and honest.
Pedders all the way.
They have some many different options for any application.
Old 04-15-2008, 11:35 AM
A_VAS's Avatar
Bluebandit, if you are Jersey you can get the 5/16 raised red springs as shown in the pic from Frank (Rocksand Racing)....maybe he already pm'd ya.
Nice parts in there Batboy...I got the same setup from Chris. So far so good.....
Rob
now since I'm derailing the thread....whats the p/n for the Koni adjustables that fit GTO ?
thanks
Quick Reply: Rear Springs
