Gear-dependent vibrations
Background..
RPM-Stage IV T56,
LS6 clutch,
Alum. flywheel
stock driveshaft
4.10's
Poly bushings everywhere
u-joints are all tight and greased
gear setup is good and within specs
there is a little bit of play on the output, but nothing the gear guy said was concerning at all.
If I'm driving around 60 in 6th, I get a mild high-freq. vibe, can be felt mostly through my butt. If I drop to 5th, the vibe is gone at the same speed. This also happens in 5th around 40-45(Not 100% on the speed, but it's around there)
I'm very familiar with identifying speed-dependent vibs, but not usually gear-dependent ones..
Ideas?
RPM-Stage IV T56,
LS6 clutch,
Alum. flywheel
stock driveshaft
4.10's
Ideas?
5th and 6th driven gears are both on a common spool-type gear. That is, 5th&6th driven gear is1 part with two gear cuttings on it. It may be that the spline & journnal this gear is pressed on to attach it to the main shaft may not have a tight fit (anymore). It could also be a simple as a bent mainshaft. If you have lost rear gears or a propshaft in past history, a bent mainshaft is quite commonly a secondary damage.
Fortunately, this trans was purchased straight from RPM, and there's been failures like the driveshaft or gears..
The PO drove it with a failing master & slave cylinder which caused other issues, so I'll have whatever shop I take it to (probably tick) look at 5th and 6th closely.. thanks.
