Drag Racing Tech - Jersey racers... or sea level duders
ChrisUlrich
04-09-2008, 07:53 PM
What type of cam only times are we running around sea level?
I am hoping to achieve 120mph traps in a 10bolt 6 speed car with a cam+bolt on car.
Pacesetter 1 3/4 LTs
Pacesetter Y no cat
Loudmouth II
LS6 Intake
Ported Stock Throttle Body
UD Pully
Dynotune
Cam of choice
Anyone doing this around here? Without using the Vindicator, T-Rex, or MS4? Cams that will allow a 6500 rpm shift point?
cbrrmike
04-09-2008, 09:32 PM
i'm stock internals with everything else on your list plus a ewp and trap at 114-115 at englishtown and atco, i have a 12 bolt with 4.10s and full suspension though
IGNANt
04-09-2008, 10:00 PM
those cams allow 6500 shifting... higher durations = higher peak usually...
INMY01TA
04-09-2008, 10:03 PM
Well I ran 11.89@118, 12 bolt and 1.65 60ft tho. Most guys I know trapping 120-122 are cutting mid 1.5 60s, you may be able to do that once or twice with a 10 bolt. lol
ChrisUlrich
04-09-2008, 10:04 PM
Trapping 114 with a cam car? What kind of et then?
EDIT: I thought more spin = higher trap? And whp is a measure of trap speed?
cbrrmike
04-10-2008, 07:17 AM
no, i mean im trapping 114-115 with a bolt on car...i know its not what you asked, but i was giving an example, i would think similar mods with a cam would get at least 118-120mph
WS6TransAm01
04-10-2008, 09:35 AM
I ran low 11's @ 120+ in my friend's CARTEK 3X cam only Camaro, weight reduction, 16" M/T ET Streets, with a 9"
Dragkid1917
04-10-2008, 12:38 PM
i went 118.8 mph at englishtown the other day with stock intake/throttle body and no Ud pulley. I went low 11.50's but know that i have some weight reduction and it was like -1000 DA out however there was no tail wind at all. I could have probably trapped around 122 Mph with a full intake and ud pulley, and If i went nuts with stuff like electric water pump and serious suspension probably 123-124 mph. But only in that nice weather, on the avg hot summer day id be happy with 120mph.
Demonicbird00
04-10-2008, 11:00 PM
check sig
you should be able to hit 120......but you have to be careful of the rear or else you wont make it past the 60'
-brandon
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
