Spec 3+
Spec 3+
As stated im thinkin bout buying the SPEC 3+ kit from LMPerformance and i just wanted to know, is there any thing else i absolutely NEED to buy, im on a budget!!! The car has 112,000 miles on er'? Any input will help.
nah, the LS2 Flywheel wieghs quite a bit, but you cant beat it for the price, and factor in drivability and power...that is one killer deal. I think it would be great for your setup, im making a shade over 500RWHP and im gonna take a crack at that clutch as well, Ive heard a couple bad things, but most the reviws for it are positive. i say give it a crack. the loss of a couple HP with a heavier flywheel wont be noticable
Buy a new slave cylinder while you are at it. Your flywheell will also need a resurfacing as well. Do not cheap out on resurfacing the flywheel, it needs to be done or the clutch will not last long.
anything but spec .. just pulled a tranny out 5 times cause they told me at spec nothing could be wrong with the clutch i replaced the master and slave cylinders , fluid dot 4, new flywheel , shimmed the slave , and finally took some measurements the pressure plate was off .090 that almost an 1/8 inch.. then had to pay shipping back to them and wait two weeks for them to check it and send me a new one.. they still said maybe something happened in shipping... yea right the steel grow in shipping ... haha
You will hear bad **** about every aftermarket clutch out there. Most of the problems come from a bad install and bad driving habits. Sometimes yeah of course there are manufactuer defects, but not most of the time.You cant slip any aftermarket high power clutch like you can a stocker and expect it to live as long as a stocker.
I have a Spec Stage 3, it doesn't slip, but chatters when you take off from a stop sign.
It is OK for racing, but crap for the street. They are way overpriced.
