tranny problems only 1,2,r work
Old 04-10-2008, 04:31 PM
johnLs1camaro's Avatar
Default tranny problems only 1,2,r work
well my car does reverse fine and then it goes into first eveything is fine and then into 2 and everythings fine and when the car shifts into 3rd its like the car is in neutral and the car just revs up when i put on the gas does anybody no what this would be and when i mash the gas when that happens it will downshift to 2nd just fine??? also if it matters i have a tci 3500 stall and H/C in the engine my car is a 98 z28 camaro thanks for the help
Old 04-10-2008, 04:40 PM
LS1Tech Sponsor
performabuilt's Avatar
Unfortunatly it sounds like you have lost the 3-4 clutch set , Either the snap ing has broken out of the drum if this was sudden or if gradual the 3-4 clutch set has failed. In either case you will either be going into or replacing the unit, Sorry
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-10-2008, 07:17 PM
FLT
FLT's Avatar
Agreed that you have suffered a 3-4 clutch failure. Time for a new transmission. Feel free to give us a call. Vince
Old 04-11-2008, 12:47 PM
do you all sell any high performance rebuild kits
Old 04-11-2008, 01:53 PM
FLT
FLT's Avatar
Sorry we currently do not offer parts. Try to4l60e rebuild kits, etc. I'm sure there is a ton that will come up. Good luck. Vince
