are ws6 rear springs diff. from regular t/a
Old 04-11-2008, 02:14 AM
SD99TA214's Avatar
Default are ws6 rear springs diff. from regular t/a
i searched it but didnt find anything definate... no one that had known for sure...... i just noticed my t/a seems to sit higher in the rear. but it could just be me seeing things. any help would be appreciated.
Old 04-11-2008, 06:25 AM
JD_AMG's Avatar
nope, same springs.
Old 04-11-2008, 10:32 AM
SD99TA214's Avatar
you sure? i just want to know for sure thats all, have you swaped them before and saw no change?
Old 04-11-2008, 10:44 AM
JD_AMG's Avatar
Don't need to swap them to know. The WS6's package didn't include springs, only a front sway bar and supposedly 'better' shocks.
What you are probably seeing is the stock 16" wheels are leaving more of a fender gap than the 17" WS6 wheels do.
If you want a cheap "fix" search "heater hose mod".
Old 04-11-2008, 11:13 AM
slow's Avatar
I always thought that 96-some 00 cars got different springs (1le content) but the mid 00-02's were regular V8 springs.
Ryan
Old 04-11-2008, 11:17 AM
SD99TA214's Avatar
well see i got 17"x10.5 ttms with 285/40/r17's on the back and my car sits higher then all the ws6's i see, surly shocks cant be making it sit higher, could they???
Old 04-11-2008, 01:35 PM
stockerws6's Avatar
Originally Posted by JD_AMG
nope, same springs.
I think this is the wrong information. I am pretty sure the WS6 has higher rate springs. Don't know if it makes a difference for ride height though.
Old 04-11-2008, 01:48 PM
SD99TA214's Avatar
well theres 3 stock ws6's in my area. ALL are stock and all are lower then mine............... sombody has got to know this info FOR SURE. i appriciate opinions but fact would be great. i dont want to "lower" my car, i just want it to sit like my previous cars (2 prior ws6's)
Old 04-11-2008, 02:02 PM
WS6_00's Avatar
ws6 package:
Ram Air hood
WS6 raised lower air box
32mm front sway bar
1LE springs (for '98, '99, and some '00s)
WS6 badging & Ram Air decals
Lower restriction catback
17" high polished wheels w/ 275/40/ZR17 tires
Jounce spacers for 17X9" wheels
Power steering cooler
http://www.theformulasource.com/foru...html----source..
Old 04-11-2008, 02:57 PM
robertbartsch's Avatar
Stock Gm springs - f BODY V8 - 1998-02:
Front = 290 lbs
Rear = 114 lbs
1LE springs:
Front = 360 LBS
reR = 130 LBS
Old 04-11-2008, 03:00 PM
...According to the spring chart I have, the regular GM spring for v8 f-body cars and the 1LE spring should result in the identicle ride heights, however.
Old 04-11-2008, 03:06 PM
z28bryan's Avatar
I think the 1LE rears are progressive from like 130-170 by the way...
The WS6s I'm pretty sure have the same springs as the normal TA's except for 1LE models..... I don't know exactly. Wasn't the later model 1LE packages made by SLP?
Old 04-11-2008, 03:16 PM
WS6_00's Avatar
I don't think SLP ever touched the WS6, it was ASC. It's a diff. story for the camaros...
could be mistaken though but that's what i got
Old 04-11-2008, 03:40 PM
WS6_00's Avatar
Higher rate front springs (360 lbs/in)
Variable rate rear springs (130-180 lbs/in)
Old 04-11-2008, 06:06 PM
LS1W66's Avatar
Originally Posted by WS6_00
ws6 package:
Ram Air hood
32mm front sway bar
This is the same info I have seen.
Old 04-11-2008, 07:05 PM
SD99TA214's Avatar
then what the crap........ well if this helps ANY for you guys to understand what im dealing with........... i have a 17' ttm with a 285/40 r17 kumo, the tire is 3 3/4 from the wheel well. it doesnt sound like its high but it sho looks it.
Old 04-11-2008, 08:19 PM
WS6_00's Avatar
well just get some strano's and konis and you're all set
Old 04-11-2008, 08:44 PM
SD99TA214's Avatar
well my buddies car is stock suspension and he runs 6.12 in the 1/8 weve been working on it for a couple years now and i love the way his car works. hes got a ws6. i guess alot of it could be that a girl owned my car and its a auto so it doesnt have a history of bieng run hard and lauched hard so that could account for the springs bieng so "strong" in the back. no wear and tear sag.
Old 04-12-2008, 03:13 PM
WS6_00's Avatar
or maybe the previous owner replaced the springs.......
aftermarket suspension thats dialed in > stock suspension
Old 04-12-2008, 03:45 PM
SD99TA214's Avatar
he bought it new. i think that its just cuz it hasnt been abused. stock hight with no wear i guess. haha ive just excepted it. thanks for the input.
