Fueling & Injection - Fuel T block fitting under car near rear driver wheel.. what size are the fittings?
Avengeance
04-12-2008, 12:26 AM
What is the thread size? I know the in and out are the same but the one that returns to the tank is a smaller size.
Thanks in advance. :chug:
Avengeance
04-12-2008, 02:38 PM
Heres a photo. I need to know the thread size of the circled fitting. I know some of you have plugged this with a cap... what size did you use?
http://images36.fotki.com/v1155/photos/3/37057/107609/IMG_2893-vi.jpg
Tiger2o69
04-12-2008, 02:41 PM
I was wondering the same thing.. I need to plug the one that comes from the fuel filter.. I know its not a 3/8 lol..
Avengeance
04-12-2008, 02:53 PM
Figured it out. I knew I had seen it plugged somewhere... its 1/4" NPT. I know the inlet and outlet size is different. I wouldnt mind knowing that size too for future reference.
Found it here.
http://ls1tech.com/forums/showpost.php?p=6919982&postcount=8
Old Geezer
04-12-2008, 04:12 PM
Those are flare fittings that have straight threads.. not NPT, tapered threads. The threads are not used as a seal. There's an internal flare seat in the fitting, and 1 on the tube.
A good AP store will have the correct plugs.
JoshuaGrooms83
12-14-2012, 12:15 AM
from anyone thats done this, does it matter if you use a 1/4" NPT or a 1/4 flare plug? as long as it doesnt leak either should work right?
Old Geezer
12-14-2012, 07:19 AM
go ahead and try it. If you fuck up the threads, by forcing a pipe plug into a fitting that requires straight threads, and it still leaks, what then??:cry:
It's a metric o-ring fitting. Either 14mm or 16mm if memory serves me right. I found the answer a couple years ago somewhere in this section.
Here it is, post#5.
http://ls1tech.com/forums/fueling-injection/945507-factory-return-line-size-plug.html
JoshuaGrooms83
12-14-2012, 12:34 PM
thank you very much, thats the anwser i needed
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
