Installing UMI control arm relocation brackets
I bought a set used so I have no instructions. These are the bolt on kind. It looks pretty easy but should I put a jack under the rearend while removing the shock bolts? I wasn't sure how far the rear end will drop
i had to cut that off and grind it down in order for the brackets to fit, i also forgot to plug my passenger side abs sensor back in. whoops
