402rwhp/367rwtq = 11.51 @ 116.59
Made a couple mid 11.50 runs this week in my 2000 SS. Stock weight with converters and Magnaflow catback and drag wheels/tires.
All I can say is the Yank 4000SS suited my car perfectly. Was previously running a Yank PY3400 in the car which was completely wrong for my combo.
The Yank 4000SS picked me .660 over the Yank PY3400.
Combo is mild LS1 with AFR 205's, 224/230 Comp XER, Kooks 1 7/8 tube, Fast 90/90, A4, Ford 3.70 9", and Magnaflow cat back.
Went 11.51 @ 116.59 1/4
60' - 1.575
330' - 4.663
660' - 7.295
660' MPH - 93.25
1000' - 9.578
Shift points were set @ 6100. Went to raise them to 6450 and make another hit and it started to drizzle so they called it for the evening. Thinking I can get into the mid 40's next time out
60' - 1.575
330' - 4.663
660' - 7.295
660' MPH - 93.25
1000' - 9.578
man that 9 inch is killing your weight, they are heavy sobs. i bet you should but in the low 11s, that seems to be a baby cam, but nice runs nonetheless. that seems like quite a bit of work to me and only having 402 rwhp? ive seen cars with heads and cam making over 450 to the wheels, even on a mustang dyno.
QUOTE=DevilDougWS6;9141897]man that 9 inch is killing your weight, they are heavy sobs. i bet you should but in the low 11s, that seems to be a baby cam, but nice runs nonetheless. that seems like quite a bit of work to me and only having 402 rwhp? ive seen cars with heads and cam making over 450 to the wheels, even on a mustang dyno.[/QUOTE]
Yep, I hoped for 450 to the wheels just like everybody else, but it ain't happening here! To justify the numbers slightly, my converter was unlocked. Nonetheless - 11.50's in the 1/4 @ 3700lbs ain't too shabby for a 346 with 224/230 cam and some low 6100 RPM shift points.
[/QUOTE]
Yep, I hoped for 450 to the wheels just like everybody else, but it ain't happening here! To justify the numbers slightly, my converter was unlocked. Nonetheless - 11.50's in the 1/4 @ 3700lbs ain't too shabby for a 346 with 224/230 cam and some low 6100 RPM shift points.[/QUOTE]
Good answer. As long as the track times/results are there, who cares what the dyno says. Id rather have that power and run mid 11's than have a dyno tell me i'm making 450+ hp and only run high 11's
Good answer. As long as the track times/results are there, who cares what the dyno says. Id rather have that power and run mid 11's than have a dyno tell me i'm making 450+ hp and only run high 11's [/QUOTE]
Isn't that the truth.
I would be very pleased if I do, not that I am not already
