Does top end cleaner go into the MAF?
Re: Does top end cleaner go into the MAF?
Do not run it through the MAF. You need to disconnect the MAF and run directly into the TB.
You will also need ot clear the MAF code cause it will set the SES light.
a little advice keep it in for a while before firing her up
