EASE questions
Old 07-31-2003, 08:08 AM
67ls1CamaroProject's Avatar
Default EASE questions
I have made a custom parameter list, but everytime I hit the record button it changes back to the previous data that I recorded. How do I make it use my custom list? Also, how do you view the average of the data collected. I have the latest version and thought that it had an averaging function. Looking for the easy way out so I do not have to figure it out on my own.
Thanks,
John
Old 07-31-2003, 10:30 AM
Team ZR-1's Avatar
Default Re: EASE questions
You always need to Login first,
reason it is at the top of the menu when you load the scanner.
Once logged in it scanner recalls the last group PIDs that were used and what car was connected.
You then can make up your own PID group(S) and being your logged in can click on parameter icon and then click on User and select from the groups you made up.
If you do NOT login then scanner is in factory default mode.
As to averages select the Meters icon then select
the min/max/avg tab.
This then shows you the realtime value and below that what the minumum, maximum values that PID has had for that scan or record and the running average which is good for like the fuel trims, timing, knock, etc.
This works when scanning, recording or when you play back a recording.
Each meter then has a PID tab and you select what PID you want for each meter.
