Best heads for 224 cam with 112 lsa?
Old 04-14-2008, 07:07 PM
kingsey's Avatar
Default Best heads for 224 cam with 112 lsa?
Thinking 5.3's from TSP? School me
Pure street car, full bolt ons blah blah not revving it to the moon on a daily basis either
Old 04-14-2008, 07:41 PM
mchdg86's Avatar
Great heads for that cam. I put down 398 rwhp and 379 rwtq through a locked A4 tranny. My best time so far with this combo is 11.79 at 113.5 mph.
Old 04-14-2008, 09:17 PM
Xtreme57's Avatar
What's the $$$ range for those heads?
Old 04-15-2008, 11:14 AM
chieftransam's Avatar
I bought the stage 2 ls6 heads PP.
Old 04-15-2008, 11:54 AM
BIG_MIKE2005's Avatar
I love my 5.3 heads. They are port/polished(by Bo White) & milled .018" w/car valves in them. They flow really well especially for the lift on this cam. And they will bump up your compression a little too.
Old 04-16-2008, 09:50 PM
kingsey's Avatar
Been looking at those 5.3's more and more. Although afr's look soo nice on the block i cant see spending over 1000 dollars more.
Any one else with input?
Old 04-16-2008, 10:55 PM
99blancoSS's Avatar
The PRC 5.3 is a good head and good deal, will go with that cam nicely. MTI just released new pricing on their ported heads and those would be another great option, TEA has 5.3's as well as ET.
If you wanted to spend more money and step into an after market head then you have AFR, ET, TFS, DART, Edelbrock.. all fine choices. With your cam no need to shave the heads, you should retain plenty of low end grunt with a 224 cam. LS6 intake is fine, or you can step up to a 90/90 or 92/92 as it is now.
Old 04-17-2008, 12:55 AM
MrElectric03's Avatar
I would go with the stqage 2.5 5.3s from TSP, they flow great and for about the money cant be beat. My cam is a 226/232 and I think I am going to try TSPs new 2.5R head which has a 2.055 intake valve for a little more flow. You wont find these on their site yet as Jason just finished them but you can contact him if you are interested.
Old 04-17-2008, 03:26 AM
TransAmcoupe98's Avatar
I would go for the 5.3 heads. If your looking to stay N/A, they will love nitrous as well.
Old 04-17-2008, 03:53 AM
Grimes's Avatar
TSP = Texas Speed & Performance, the company that sells PRC brand heads. Same heads as in the other thread.
Old 04-17-2008, 07:10 AM
AU N EGL's Avatar
I have a 224/224 .581/.581 112 comp cam
on polished ( cleaned up a few burs but not ported) 243 LS6 heads on an 03 LS6 block. Comp 981 springs
TPIS LTs, Random Tech High flow cats and X-pipe then straight pipes.
underdrvie pulley, my own CAI, TPIS tb, 3qt accu-sump and oil cooler, MN6
Just over 400 rwhp and 400 rwtq
Old 04-17-2008, 08:14 AM
TXZ28LS1's Avatar
seems like the best results for the 224 cams are with some 5.3 heads. seen alot of guys make good numbers!! AFR's would be killer too!!
Old 04-17-2008, 10:52 AM
kingsey's Avatar
Yeah it seems 5.3's are the way to go.
Just wondering if the ls6's would be better for the street or the 5.3s
Old 04-17-2008, 11:03 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The shorter intake runner on the 5.3L, as well as the smaller combustion chamber make the 5.3L the more popular choice for street use!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-17-2008, 11:50 AM
cookba's Avatar
what about a set of the Stage 2 ETP LS6 heads? and a Tony Mamo ported 90/90?
Old 04-17-2008, 06:02 PM
Moderator
davered00ss's Avatar
AFR 205's mill .024 & use a cometic gasket, or Mill .030 and use a stock GM gasket. With that combo, I put down 430rwhp/403rwtq.
Old 04-17-2008, 06:03 PM
Moderator
The 0.024 mill with the cometic will give better quench & produce a little more power. I did not want to deal with leaks, so I used a stock gasket & just milled them a little more. Runs fine on 93 octane.
Old 04-17-2008, 06:48 PM
kingsey's Avatar
Yeah i got 93 all the time. Say i go to a bigger block or a 383 can i use my 5.3's or would i need to get new heads then?
