T56 assembly question
Old 04-14-2008, 08:08 PM
98RedZone's Avatar
Default T56 assembly question
I am having some trouble with the 5th/6th gear shift rail. When I put the case on, should I have it in neutral? does it matter? Should I put the guide bolts in right after I put the case on? 1st-4th seem right, but 5,6,R do not, so I think they came off. I don't have the guide bolts in. Thanks for any info.
Old 04-15-2008, 08:29 AM
calhoon's Avatar
The linkage must be in neutral when you install the bolts. Place the 5th/6th/rev rail to mesh with the interlock. When the case is installed, lift up SLIGHTLY on the 5th/6th / rev rail end and the bolt should go in easily.
