LS2 GTO HEADS ON A LQ4 how will it work?
Hi everyone. I need help before I attempt to do this .Iam installing a stock LQ4 out of a 2002 silverado into a 98 crown vic .I need to install a car intake for hood clearance i was gonna use a regular ls6 intake but My buddy has a 2007 6.0 gto he is installing a set of patriot heads and a fast intake on and He said that i can have his heads and intake .Will they work on my LQ4 with out any piston to valve clearance problems and what kind of compression would i see with those heads .Are the LS2 head's chambers smaller than the LQ4 chambers . Thank you for Any info i can get on this subject.
Thanks John
Thanks John
They are 243 heads i might still do it they are really low mile heads he has 12 thousand on the clock.plus i will use hi car intake instead of the truck style.Thanks for the info.
