What part of the 10 bolt is the week link???
Re: What part of the 10 bolt is the week link???
the differential, the axles, the ring gear, the pinion gear, its all weak. I've seen each one of these components be the broken item in any given 10-bolt that failed
FB is right, i're primarily broken pinions first and ring gears as a result, but it's axles, carriers, ect.. that goes as well.
I've broke a Torsen, Carrier Bearings 2 times, and then busted the ring and pinion (3 ring gears broke off and cracked like 10 other ones) lol.
ZzzZZzz 10 Bolt is Junk.
